CUDA Lock Test
Phil -- if I recall correctly, you mentioned in one of the old threads that the CUDA can take around 450 in/lbs of force to break. I'm curious to know how you tested it to reach this finding?
"It is better to understand a little than to misunderstand a lot." -- Anonymous
Titan,
Sorry I do not recall that post. Could you remind me where you read it?
Sadly I am in need of some more "Mental Floss"
Titan,
That sounds more like my post on the topic!
Test involves hanging 100# weight approx. 3 3/4" from pivot.
Phil, just a note of appreciation for you being so direct in reply to a question on lock strength. Its a trend I would like to see more makers follow.
-Cliff
Phil -- thanks for your forthrightness. Do you think the CUDA's lock strength is sufficient for its intended use?
Titan,
Yes I do.
Although "strength" is a topic of perspective!
My CUDA tests at 375# forced several of the samples to "Fail". My definition of failure is that the liner lock bar moves all the way over to the other liner & the liner lock starts to crumple. At this point the knife is difficult/impossible to close. Warranty repair would consist of replacing liner lock & any other parts that may have been damaged (at no charge, of course).
None of the locks I tested "defeated". My definition of defeated is when the liner lock moves away from the blade allowing the knife to fold close.
I am reviewing several approaches to increasing the 375# results.
Perhaps you should consider the Bob Terzuola CQB1 Fixed Blade CUDA if your are planning on using your knife as a hammer!
Was the mini-CUDA tested as well? What might the results be?
I've got a mini-CUDA some time ago
and I've made it my everyday carry ever since.
It's one great knife
Phil -- ditto with clocker's question.
Mr. Janich (sp?) wrote in his 99 Combat Knives article on the CUDA about the thin liner as seemingly weak for defensive application. Do you think a thicker or harder liner material would make it crumple well above 375? Although there is no standard figure yet, I think a number quality folders (e.g., Military, Sebenza, SOCOM) are hovering around 450-500 in/lbs based on Spyderco's testing.
