Hi everyone,
today I would like to show you another Cudeman knives from my knives collection - Cudeman MT-4 and Cudeman 327-M.
These three knives belong to the survival series and are suitable for the bushcraft, hunting and angling activities. Two of them are MT-4 folders (384-K with handle scales of cocobolo wood and 384-W with handle scales of black/red micarta) and another one is the 327-M folder with the gray/black micarta scales. They are sturdy working knives with liner lock system. Made in the city of knives - Albacete, Spain by Cudeman company.
Blades are made of the Bohler N-695 steel hardened to 58-60 HRC and all was scary sharp out of the box. Each of them shaves hairs with ease. MT-4 series has the blade of 3 mm thickness and 327-M has blade 4mm thick. Both models have liners and backspacers made of stainless steel and are opened by a two-sided thumb stud. Very grippy notches are on each blade spine. Steel backspacer at each handle end works also as a glass breaker. 327-M additionaly has nice ornamentation on the backspacer. MT-4 have elegant bolsters of A-304 steel. Blades have 10cm length, but the 327-M blade is wider and has larger very comfortable handle, proper for people with big hands. Liner lock goes very deep after opening which I think is needed in a such knife for safety work.
Each knife is equipped with the high quality cordura sheath. These sheaths are padded inside and are closed with velcro and small buckle on adjustable strap. Two horizontal straps and one long vertical strap are on the back of the sheaths. These straps are compatible with the Molle system and allow many various fastening options, so you can attach the sheath to the belt, backpack, military equipment etc.
The MT-4 overal lenght is 21,6 cm, 327-M has 23,4 cm. At the end of the handles are lanyard holes with steel sleeve inside.
Cudeman MT-4 specifications:
☞ Overall length: 21.6 cm
☞ Handle length: 11.6 cm
☞ Handle Material: Cocobolo wood (384-K), bicolor micarta (384-W)
☞ Blade length: 10.0 cm
☞ Blade thickness: 3.0 mm
☞ Steel Blade: Bohler N695 58-60 HRC
Cudeman 327-M specifications:
☞ Overall length: 23.4 cm
☞ Handle length: 13.4 cm
☞ Handle Material: Bicolor micarta
☞ Blade thickness: 4.0 mm
