Cure for scratches???
I have a sword that has some scratches on the blade. I was wondering if there is any way to cover them up. I was thinking of taking some fine sandpaper and giving the blade a brush type finish. Would this be bad for the blade? Is there a better method??
Any help would be appreciated. Thank you.
Louis Buccellato
http://www.themartialway.com
Louis, if the sword is antique and you want to keep it antique, don't do anything with it. If the sacratches aren't too deep, try rottenstone or pumice (check a woodworking store)to take the scratches out. If you can't find those, try an automotive finish store, they should have a polishing compound that would take out swirls. They'll also have snadpaper up to 2000 to give a mirror finish (depending on what kind of finish the sword has in the first place). Of course,the other option is to sand the whole thing to give it a satin finish (use a lubricant, and start with a higher grit and work your way down untill you start to remove the scratches and then work back up, steel wool works well for satin). Hope this helps.
"Better to reign in Hell, than serve in Heav'n"
John Milton
There are only two types of people; those who understand this, and those who think they do.
bcaffrey,
I used the scotch brite and left it with a satin finish. The blade is now beautiful!!!! Thanks for the tip
Louis Buccellato
