Curiosity
David W Babcock
Black Metal Forge
Has anyone ever tried a multiple folded billet out of something like 1095/1080/1075/1045 for a roughly .725 carbon billet, but more importantly my question is can you obtain a little hada, grain pattern like in Japanese blades.
I have used bloomery steel before and it’s definitely different to work with than modern steels, but I’m curious if I made maybe an 8 layer billet out of alerternating 4 steels with numerous folds would I get any pattern in the steel?
I’ve been thinking of trying it but curious if anyone else ever has?
Sounds like a lot of work for a little gain, if any. You might get some pattern, but what you are really doing is introducing failure points into your equation, at least in my opinion.
  • Like
Reactions: weo
Your scenario to end up with .725% carbon is wrong. You would likely end up with at least 10 points less. You loose carbon every welding heat. I would take out the 1045.
I have used 1095 and 1084 to get a hada effect. It probably ended up around .70% carbon.
You need a minimum of 1000 layers, and 5000 isn't too much. Even a single steel will create a hada with many folks. The folds create a boundary layer each time that will show up in the final steel.
Mix W2 and wrought iron and run the layer count up, make sure it is W2 heavy to get enough final carbon content. This will give you a very good Japanese look.
Hoss
I have a lot of wrought iron on hand I generally use for San mai and it in itself produces a nice wood grain effect. Sorta worried about how much in folding I’d lose as it’s so low in carbon, but I hear you on loading up on W2, something else I have a fair bit of in stock.
I’m asking as I actually have about 3.2 kg of NBTHK tamahagane so I want to practice the forge welding techniques from both direction folds, and a dozen times as I’m not touching this steel (I have worked with bloomery steel before so I know what I’m in for) until I know I can do it justice. It might sit for a couple more years
