- Jul 7, 2015
Hello, first post.
I've been a hobbiest making knives by the material removal method for 20 some years now and have for the last couple of years been playing with forging a little while gathering and building the required equipment. I am a CNC machinist/programmer in the aerospace industry for my "real" job so I have access to materials and equipment to build just about anything within reason.
I have built a decent coke forge as well as a pretty nice tube based gas forge and have aquired several vintage anvils in the 60-150lb range..... now I have decided to build a custom anvil in the 300lb range, and will be doing so by fabricating several pieces and then welding them together. I have the capability to heat treat the material to whatever condition suits the project best, as of now I haven't decided the particular material of which I will machine/fabricate the body of the anvil.
My question is would it be acceptable to build the main body of the anvil from say 1018 and then apply a working surface of a higher grade steel? I can build the anvil entirely of any material within reason, but it would be easier with 1018 from a machining and welding standpoint.
if push comes to shove I can build the anvil from solid forged billet as we have the capability to 6 axis machine workpieces up to 30'x60'x8' but by fabricating it I can do it basically for free using drop material.
Any suggestions or help appreciated.
I'm also going to build a PH and a heavy forging press but one thing at a time.
