- Apr 6, 2013
A while back I made some custom wooden grips and a leather sheath for my BK2.
This resulted in a pair of BK2 handles lying around. I reckoned the best way not to lose them would be to put them on a custom knife.
I merged a whole bunch of elements that I personally like into the design for this blade:
* 8mm 5160 spring steel.
* BK2 handle and pommel.
* Busse TGLB blade shape, size and finger choil.
* BK16 flat grind.
* Modified reverse thumb ramp of the BK7.
* Convex grind.
Work in progress pics - bad cell phone quality since my hands were damn dirty most of the time:
Blade back from water jet cutting. I am very impressed with their accuracy. Cutting the blade cost $36. The steel was $10 for a 1m bar of 8x70mm
Desired edge thickness marked before filing.
Jimping detail. Here especially you can see how well the water jet handled the cutout.
Custom made filing jig. This worked very well. I think the photo shows exactly how the thing works.
Blade clamped and busy filing. I gave up at this point and had the blade belt sanded. I should have used a rougher file but for some reason none of the local hardware guys had any.
Before we started with the grinding, the blade was heat treated (or normalised) first to prevent issues while it was being ground. Apparently the heat up / cool down during belt grinding causes problems with 5160.
Finished belt sanding. Since I was not sure about the accuracy of the water jet, I left a little margin around the handles just in case. This was totally unnecessary and caused me a bit of extra work later on.
The blade was also hardened to about 58 on the rockwell scale. A local knife maker did the heat treat and belt sanding for me. He really did an excellent job on the belt sanding and ht!
Cutting edge. To prevent warping we left about a 2 - 2.5 mm cutting edge. Not sure if this was really necessary on a blade this thick, but decided to play it safe.
After sanding the blade to 100 grit. I used the same filing jig for the sanding to get everything as flat as possible.
Finished sanding.
Because of the thick edge, a convex grind was my only option for this blade. I also thought that the durability of a convex edge would suit the character of this blade well.
Convexed the blade by filing about a 30 degree bevel as far as I could, then belt sanded on a small tabletop belt sander. Stopped screwing around with this when I cut myself with the tip ; )
Stuck the blade in a couple of lemons to see what the patina will look like.
Still to do:
I think the convex edge can be taken up a bit higher for better cutting. Some cutting / chopping / slicing experimenting will be required. Talking of experimenting - this morning I tried whacking the blade at a nail - the wood I put the nail on gave way so the nail was only cut through about halfway. No damage to the edge whatsoever.
Finishing - I am a bit undecided on this. I intend to use this blade and use it hard. Dont think I am going to bother sanding to higher than 200 grit.
Sheath - probably kydex.
It weighs just over 600g with the handle. The balance point is within a couple of millimeters of the two holes in the guard.
Take some SLR photos....
* BK16 flat grind.
* Convex grind.
Finished sanding.
Still to do:
