Custom Buck Strider 889 Work Log
robotech
BANNED
I decided to customize a Buck Strider 889. And boy, did THIS turn out to be an ever changing project.
I wasn't going to worry about a work log, as this is a prototype, and I will probably make some mistakes. But, a friend asked me to do this as he was curious on how it was done.
I purchased a used Buck Strider 889 in a tan FRN, black hardware. I wanted a user as I was going to change or add new hardware as it progressed.
So, this starts after the 1st stage was completed, but will continue as I finish and I will post updates as they get done.
I am going to put on a set of lemon Yellow rough textured G-10 with black liners. Then use black 4-40 screws and custom standoffs. And maybe a low ride Ti pocket clip.
Well, after I received the knife, I found that Buck, for what ever reason, decided to put a .040 bushing on one side of the blade, and a .020 on the other. I had heard that it was done to prevent the lock bar from wedging into the far side blade/liner when the lock was worn. Considering that the lock is 50% + new, that kinda made sense.
But, after I measured everything, I am not buying that. And that bothered me.
Then I measured the liner and found it to be .050, .020 wider than the bushing on that side IF Buck had just centered the blade. Uh uh, that liner would not wedge, so I am stumped.
You could see that the blade was off center at the pivot! AND the liner lock bar was past 50% lockup, new. As this one wasn't new, it was about 80%.
This design also uses a thumbstud as the stop pin. It hits the frame to stop, and then the lock bar sets.
So after I measured everything out, I found that the inside the well width was .205. A .145 blade, a .040 bushing, and a .020 bushing. The stock standoffs are .205, so that is the well width all the way back. OK.
To be honest, I don't know why Buck went to .205 width, to start with. .155, or even .185 would have made a much thinner knife, as they use pins, not screws. .155 standoffs threaded just doesn't leave much room for the screws to seat without touching in the middle. It can be done, but is very tedious in cutting, trying, cutting, trying, etc. 8 screws.
The G-10 will give a little when you torque it down.
I WILL try that on my next one. I can cut down standoffs and pivot pins to fit. Then just use .010 or .020 bushings. We'll see.
So, to make the blade centered, I would use 2x .015 bushings on each side, and use new .205 standoffs, like the stock ones. The original standoffs are pins, and had to be drilled out. Useless, now.
I have ordered the hardware, to include new thumbstuds as these are a little worn. I also punched in a new ball detent as this one was slightly worn and flattened.
Will give more technical info when I update the post, mid week. But notice how the clip is mounted in the stock knife scales, and how I have drilled/tapped a new clip position. And the lanyard hole is only drilled through one side!
The 889 has an 420HC blade. A heavy one at that.
As I said, this is a prototype. I will do one more, only a 882 Tarani with an ATS-34 blade (I have one coming). But, it is essentially the same knife, and pinned together.
So it will get .185 (3/16") standoffs (4-40 thread), and two .020 bushing to thin the knife, and probably Toxic Green scales. And a Ti low ride clip.
But that is for another day.
To be Continued:
Outstanding, man!
You have to open a shop!!
I am not sure it would work out.
My time and labour are not free. Before I retired, my hourly wage was $56.00 an hour.
Retired or not, my time is worth a LOT to me.
And most folks don't want to pay the price.
I am waiting for some parts to get to work on this.
The 1st batch doesn't have what I need. As I said above, this project is evolving.
I have an 882 coming LNIB, that I will swap the blade (ATS-34) and clip out to the yellow frame. And use new .187 standoffs and black 4-40 screws.. This means I can go down to .020 pivot bushings.
I won't have the knife, or my 2nd batch of parts, until later this week, so there won't be an update until this weekend.
I am going to put this blade and clip back into the 882 frame. Then resell it.
I am waiting for another 882 that is an original black G-10 SCREWED together. That one will get the same treatment as this one, except for the G-10 color. Not sure yet, but maybe a Caramel Canvas Micarta.
We'll see.
The b
$56. an hour??!! Mine was $8.!!
Well, it appears you like what you do. That's always good, broh!
Rolf
Rolf
I retired at 52, and my retirement pension is about $4000 a month net, taxes, health insurance, and life insurance paid.
I own my home.
I just turned 61.
After 5-6 years of traveling a lot, I got tired of it. Now, I just try to stay busy.
And I do.
I do enjoy the work. I am always learning something, and it keeps my mind and hands in decent shape. Starting to have vision problems (up close), but, I am getting older, so no surprise.
Ive been wanting a buck 889 or 882 looks like an awesome knife. The yellow scales are very nice on the buck. Cant wait to see the Tarani when its done. Thanks for sharing.
I am still waiting for my 1st Tarani to make it a donor (ATS-34 blade and clip) for the yellow frame.
I have a LNIB Black FRN coming, and I just purchased this blue one as a user.
http://www.bladeforums.com/forums/showthread.php/999525-Buck-Strider-Tarani-Blue-G-10-PE
I am also negotiating on a Tarani 882 with factory G-10 scales, screwed, not pinned. I will put some new G-10 and hardware on it. Maybe save, maybe sell. I am going to put the yellow one's 420HC blade back into the black FRN frame and sell it.
This yellow one, I will keep.
Wow. What a score. It also has a plain edge. Makes me drool. Please do let me know if you decide to sell one. I really want one. Thanks
I will keep you in mind. Maybe in a couple of weeks, I'll have this done.
Got all the parts today, and the Strider 882 Tarani.
Used the Tarani ATS-34 blade, and the clip, on the yellow frame, and put the black 420HC blade on the 882 frame. I will probably sell the black 889 (on an 882 frame).
Will post new pics to finish this project, tomorrow, if the weather is nice.
Awhile back before I began to buy knives I had a chance to buy a Buck Tarani at an awesome price but passed for some reason and now I kick myself all the time. Only if I have known. Cant wait to see pics. Sound like alot of fun also.
Well, no good weather for 3-4 days, so I'll put these dark ones up to finish this/
I had receives an 882 Tarani with an ATS-34 blade. The stock blade on the 889 is 420HC. Not bad steel, just not as good as ATS-34.
Here are pics of the 882.
Here is the lockup of the stock 882. Typical, even for a new Busk Strider.
I took the blade and clip off as donor parts.
Then put the original 889 black stonewashed blade and clip on that frame.
Lock up is slightly better, now.
I will clean it up, blow it out and sell this one later. Have two 882's coming and don't need this one
Back to the yellow FrankenStride
I installed the new standoffs, and new bushings.
Bushings went to .020 each side, instead of .040 on one and .020 on the other as stock.
This took 0.20" off the width.
Added the 882 blade, pivot pin, and clip.
Went with regular T-9 button head screws
This shows the new blade centering at the pivot.
Lock up WAAAAY better. This is why I went to two .020 bushings and shorter standoff. To get a thinner knife, better lock up, and the blade centered at the pivot.
I am in process of making a set of dark brown canvas scales for another Strider.
Next time.
Sucks to here about the bad weather over there. The Tarani blade always has looked way better than the 420hc but both are nice. Two more 882 coming that is awesome. Could you let me know how much you want for the 889 through email? Funny. FrakenStride. Sounds cool also. Cant wait to see that monster.
After a few minutes working the action, I have discovered a few things.
As I said, tis project will evolve.
I was concerned about the difference in pivot bushing sizes, the imbalance of the blade centering at the pivot, and the width, of the stock 889/882.
I had punched in a new ball detent as the old was worn.
The liner lock is now hard to unlock, and there is a 2nd click as the ball is released.
What?
So, I find that the ball is too far into the action, and the liner lock is too tight against the scale.
So THAT is why the bushings are different.
Eh, I still won't go back to that oddball centering, I will just mill the scale out .020" to allow the liner lock to "extend" past the ball. Much like Spyderco Military and other liner locks. No biggie, but an added step.
After I do that, AND the weather breaks next week, I'll post the FINAL final pics, so stay tuned.
FINAL final pics.
I milled out the scales to allow lock bar to extend past the ball detent.
MUCH better. Even the lock up is better, LOTS left on it. At about 20%!
Oh, and for the keen eyed readers, I forgot to put in the 2nd clip screw in the above pics, so I cut one down to size and here we go.
DONE!
