The knife is a work of unimaginable beauty. I say that because when I opened the box somehow it was so much more appealing than I had expected. It's 100% amazing.
The problem is the sheath. I got the tan leather sheath because in the picture it was a flat design and generally different from the black one, which I never cared for. The one I got is basically just like the black one, but it's too small for the knife! It's too tight from the sides, squeezing the blade down into the handle. It's too short and I can't get it in enough to snap it shut. if I snap the sheath closed without the knife, I can see the knife would have to go down all the way to the stitching, which isn't possible because the bottom of the pocket tapers down at just under 45 degrees, so the leather would have to do some incredible stretching which I am not sure would be possible even if I soaked it in water first. Do NOT get the tan sheath, it sucks and it isn't the one pictured. It has a 111 on the back, which I think is the same as a 110 but with ironwood scales so I would think it would fit but it doesn't.
More good stuff on the knife itself...
The wood (cherrywood) looks great. I wasn't sure exactly what it was, but it happens to match some very expensive furniture a friend once had and I always liked.
The BG42 blade is just a little more polished than a standard 110, even though I think they are supposed to be the same level of finish. It's also more carefully finished than a 110 you would get from a store. They usually have a noticable different finish on part of the tang.
If anyone doesn't know, the BUCK stamp is similar to the old style stamp. Fancy schmancy letters instead of standard type of some sort. The front says CUSTOM and the back says DESIGNER'S CHOICE. I didn't get any engraving so I don't know how that turns out.
The edge is insanely sharp, although standard 110 comes that way too. I can't wait to see how the BG42 holds up.
