Hiya!
I go by the tag papercut on Multitool.org where I have been discussing this topic, but I figure the good folks over here might want to be informed as well. As all SAK modders know the 84, 91, and 93mm Vics and 85mm Wengers use brass pins which are on the metric standard- 2.2, 2.5 and 3.0mm. Various models use the three different pin sizes. Unfortunately, pinning is an acquired skill that is not easily mastered. For folks who want to do some simple mods this becomes an issue.
Screws and pivots can be an answer, Spyh's great mods are testament to this, but the common pivots barrels on the market are imperial standard not metric, so precision drilling is required if one currently wants to use screws. Metric pivots have been elusive for several years and do not seem to be on the market at all in the sizes for SAKS.
But, metric pivot barrels can be custom ordered. I am in discussion with several suppliers with the following spec:
1. 3.0mm pivots with M2 thread all the way through, Stainless Steel 304
2. 2.5mm pivots with M1.6 thread all the way through, Stainless Steel 304
3. 2.2mm pivots with M1.4 thread all the way through, Stainless Steel 304
The length of the pivot barrels I am shooting for is 26mm, so it is possible each barrell can be used twice (after careful cutting at home). The downwside to custom orders is that there is a minimum order size, in this case 100 (so 3*100) with each unit costing about $0.70 USD. This is actually pretty cheap, but will require about a $200 upfront cost.
I am probably willing to front the money, but only interested in acquiring about a third of the barrels (~33 of each size) at the moment. Is anyone else interested in this project?
SAKs have 3-4 pins per model, so this could set you up for a while.
Cheers
Cheers
