Custom shop questions/opinions
The Fort
Hey everyone, I'm about to order another 112 from the custom shop. I'm considering elk or ironwood for the handle material. Opinions, pros and cons, would be appreciated. Pictures might sway me one way or another also. I suspect that the ironwood would be very durable, and worry free, correct? Would it be Dymondwood, or actual full pieces? I don't have any knives in elk or ironwood, so any information would be appreciated. Thanks! Lance
Is this a knife you're going to look at, or use?
Antler is bone and wears about as good as any handle material. There are centuries old knives with stag handles that look great after all this time. Not to mention, it's gorgeous! Even in smaller pieces, like the scales of a 112. There's generally no mistaking stag.
Ironwood is a great handle material as well. Hard enough in fact that it doesn't necessarily need to be stabilized. Unfortunately though, it's not always recognizable as ironwood on smaller pieces.
If I put ironwood scales on a knife, I have the luxury of picking a particular place in the wood to make the scale. I make sure it's recognizable as Ironwood, or I won't use it. I usually start with a block and section it to a thickness that will yield 2 scales (with some cutting and finishing material as well, of course). I can see what both sides will look like before I start so I know how to layout the handle to highlight the characteristics of the wood. Then I'll split that block to "book-match" the pieces so on the belly or spine of the handle the grain is consistent so it looks like its a single piece that was split.
Does anyone know with any certainty that Buck book-matches scales and lays out the pattern to maintain the graining?
If the answer is "no", I'm getting stag.
It's not that you can't get a great set of ironwood scales on a 112; the question is: does Buck's production folk put that much care in it? I'm not suggesting they don't, I'm just don't know their process.
In any case, you'll see the photo of the material in the "build your own" 112 on the site is merely an example of the material used.
That's my $0.02...
@JB: After going through your gallery, I'm definitely getting stag. Beautiful stuff!! I think the only thing I like better than stag is ram's horn. :eek:
Keep in mind that not all stag is created equal. I'm not sure if Buck takes requests regarding what you want the stag to look like or not, but it might be worth checking out. I sent in a C&C stag knife for warranty that had perfect stag, but needed a new blade because the grind was horrible and one of the bolsters was concave. I reckon they had to replace the knife since the one I got back wasn't the same stag. What I sent had great color and texture, what I got back doesn't look or feel nearly as good. Let us know what you decide because I've been thinking about getting the same versions myself. Good luck Lance :thumbsup::thumbsup::thumbsup:
I'm not sure how much different deer and elk stag are when it comes to knife scales, so the properties may be completely different regarding the available variations. Just a thought....
JB, thanks for the link to all the great pics! MT, often times I don't know if a knife will be a user, or not, until I have it in hand. Thanks for the great info!
Thanks 300! Very informative! I think I'm going to go with the elk. That way, if I don't like it, I cans grind up the handles for other uses! :p:D:)
