- Mar 1, 2008
Just curious if anyone knows of any custom makers that use say M4, S90v or any of the other newer steels in a multi-blade slipjoint?
The way I want to interpret your post is that with experimentation, one could make this work? I did note I was looking for a custom maker. It seems playing with heat treat could yield positive results. Why not use the same steel for the spring? I understand its not easy but fully believe it is worthy of someones time to figure out. I can imagine a two bladed jack knife with an M4 main blade for general use and an s90v little slicer. I can not be the only one to dream of something like this can I?
When Sal Glesser was developing the UK Penknife, he ran into a problem with the carbides in the S30V causing premature wear on the spring, even with the bearing surfaces mirror polished. He ended up using blade steel for the spring as well, and the heat treat for that part was trickier than the blade's. M4 has as much vanadium as S30V, with tungsten and molybdenum thrown in as well, giving it an even larger volume of hard carbides. A slipjoint's backspring applies a lot more pressure on the blade than most locking mechanisms, so that may be at least one of the concerns involved. Having an expensive, hand fitted, pinned construction slipjoit that you have to rebuild every few years would be bad for the customer and maker both.
