batosai117
- Jun 5, 2007
Edit: Pics added on post 4
I will get pics up soon, but I had to blurt out to you guys what I did to my Kershaw Cyclone. I used my dremel with a fine sanding bit to put an interesting design on the blade of my cyclone.
It does have a reflective finish, but in the glare of a light, it has an interesting repeating pattern. This probably came from the hand motions I did while sanding off the blade. The pattern is exaclty the same on both sides. I also did the same "finish" to the clip as well. It helps compliment the blade in my opinion.
I also took the liberty to create a finger choil where the blade meets the finger flipper. I ate up about 1/2" of blade with my cutting bit and made an arch with my dremel. I then used the cutting bit to create some jimping on the new choil. It now resembles a Spyderco Manix, and looks very nice (pats self on back). It almost looks like it was bought that way. I'm sure there are better modifications done out there, but I'm very proud of this one as it is my first "major" modificaiton using my dremel.
I'll put up pics soon, let me know what you guys think, J.
