So, time for a new project.
First, a little backstory: I've spent countless hours these past few weeks scouring the internet for the perfect Case traditional folding knife. It has to have CV steel, be a sturdy workhorse but not too heavy and bulky, be around 3 and a half inches long when closed (to fit in my watch pocket), and look good. I believe that I've found a knife that fits this description almost perfectly - almost. I've settled on the Case canoe, which is one of the beefier knives case makes, but looks perfect for my needs, except for looks. Now, case makes a variety of canoes, but only one of them has CV steel, which is very important as I want to develop a patina. So my solution is to hit the ol' workbench, and tear this thing apart to make it my own.
The problems with the knife are all cosmetic, and may not even be seen as problems to other people. First of all, it has this (IMO) ugly unnecessary etching on the blade. From what I can tell, someone accidentally managed to remove part of it with Frisk metal polish, so I think that I'm going to be taking this route as opposed to sandpaper and buffing. I also haven't ever worked with polish before so I'm also using this as an opportunity to learn how to use it. Second of all, the knife only comes in amber bone with CV steel. Not that I think that it looks bad or anything, but if I'm already modifying the blade I might as well go all out, plus I've had these beautiful dense wooden handle scales sitting in my shop from Blade Show last year.
Basically, I want to know if
A: Metal polish can be used to remove laser etching, and if the etching turns out to be too deep, what grit sandpaper should I go to before buffing (and is dremel buffing compound OK?)
B: How would you recommend I remove the handle scales? I have a dremel and drill and other than that just hand tools.
C: is West System G-flex epoxy (an epoxy I've heard many people here use) strong enough to use without having to pin the handle down?
D: if I do have to use pins, how should I do it? Like should I fit a piece of metal into the knife to use as an anvil against the pins as I peen them down? Do I even have to peen the pins, could I just rough them up with sandpaper and smear epoxy around them and just stick them in?
Thanks for your help, anything would be super appreciated!
Conor
Conor
