Customs, Clay, and neosporin
Well, I've got a story that involves everything in the title and happened in a matter of about 2 seconds.
I was doing some double bali work with a 42 in my left hand and a bali-song cutlery custom in my right. I had been working for about 10 minutes when I looked at the clock and realized I was going to be late to picking up my GF. In the rush I choked up a bit to far on the custom when I was performing a finishing finger twirl and sunk the sharped swedge into my index finger. I didn't feel much pain but knew I was gonna bleed like a mother if I didn't cut circulation. It's at this time I remembered that I was wearing one of Clays Extreme Concealex neck sheaths. Instantly I removed the nylon cord from it and wound it tightly around the base of my index finger. I managed to do this without spilling any blood on the floor and only a small bit on my shirt. I looked at my finger an noticed the cut was no longer bleeding and looked to be a very even cut about 1/8" deep and 1/2" long. I found the hydrogen peroxide and poured it into the wound to clean any crud out that might have entered it. So there I am, index finger pointing out, nylon cord wrapped around my now bluish finger, and my custom laying on the table in front of me.
Not wanting to remove the cord and let the blood begin to gush, I found some neosporin and a bandaid. I spread the wound open so I could see how deep it was and to decide if I'd need stitches. My unprofessional decision was no stitches so I smeared a good helping of neosporin on the cut and INTO the cut, kind like filling the gap between tile with grout. I put a bandaid over it and untied the cord. No blood at all! I was quite surprised since the last time I cut myself that bed it took about an hour to completely stop with no cord or neosporin.
Now, most of the time when I cut myself, if I move my finger too much it'll bleed a little bit for the next few days. This time, I went to change the bandaid that night and the wound had RECLOSED itself. The outside layer of skin looks as if the two sides grew back together. Being the curious type I am, I began to try to spread the cut back open with no luck. I picked up a 42 and tried a bit of manipulation with it. No blood, but when the spine would make contact with that area of my finger it hurt like hell. Now, a day later the cut almost looks healed and doesn't hurt a bit.
So, my lesson of the day is, go buy an Extreme Concealex sheath from Clay, so when you do cut yourself, you have something to tie the wound off with. Make sure to FILL the wound with neosporin, and put a bandaid over it to hold the neosporin in the wound.
Once you let a blood vesel open up and start bleeding, it's hard to get 'em stopped. But, if you allow the blood to stop and clot up, it'll stop nicely.
Oxymetazoline Hydrochloride is a chemical that, if applied to a cut, will cause the blood vesels to constrict and help slow or stop the bleeding. "Great," you say, "but where am I gonna get any Oxymetazoline Hydrochloride?" Well, it's the active ingredient in Afrin Nasal Spray and many other similar nasal spray products. I've had great luck pouring this stuff on a cut. I do, however, suggest separate bottles for cuts and for nasal use if you so desire.
Last night I was flipping my brass Manila folder, and trying to figure out how to switch from a thumb twirl, into a finger twirl, and somehow had my index finger out of the way (it usually stops the blade on the "safe" part). I flipped it over, and the factory sharpened swedge edge was resting on my the knuckle of my middle finger...
Then like in the movies....
Almost real slow....
The Heavy brass handle, ( one weighs almost as much as a BM42 ) swings a graceful arc and SMACKS into the blade, making a very clean gash across my knuckle.
Much Blood!
I've figured out that the pain really doesn't hurt so bad, it's the feeling of amazement/disbelief/regret that really hurts.
It's healing nicely.
Well I haven't really cut myself all that much.....actually I havent cut myself at all with my bm42a. I have stabed myself countless times with it though. Even when the blade is taped for static throws and arials the "needle tip" stabs right through my electrical tape.:mad: Oh well it doesnt really hurt. All you feel is a prick !
Some how I did loose that "needle tip". I "attempted" a y2k roleover with tape on the blade and point, it didnt work as usaul. It hit my ikea rug and there is carpet under the rug. I figgured that it was fine. I looked at the "needle tip" and I was amazed that it was gone !:mad: I could see the tip bent to a side:mad: :mad:!!!!! Well as you could figure, I was pissed. Eventually I just toke my gatco ceramic sharpener and took off the bent point.:( I miss my point.:(
Another neat trick is to spray some Chloraseptic on the cut, then you can keep manipulating because the cut will be numb!:D
I just cut my thumb about 10 minutes ago relatively bad (it bled a bit), and it's already healed.......
I think I have some kind of mutant healing factor ;)
