Customs!!
So I mentioned a few weeks ago that I had not received my CQC7B due to it being taken by customs.
I have had a response back from my letter to them and have been informed that I can't have it back as it is classed as a "Gravity knife". Now I was not sure what that was so I have looked it up. Here is what I found:
A gravity knife is a knife with a blade contained in its handle, and which opens its blade by the force of inertia or gravity.[1] As the gravity knife requires gravity or spinning motion to propel the blade out of the handle, it differs fundamentally from the switchblade, which opens its spring-propelled blade automatically upon the push of a button, switch, or fulcrum lever.[1] The main purpose of this opening method is that it allows opening and closing to be done one handed, in situations where the other hand is occupied. A major historical use has been in issue to parachutists to cut off their parachutes when tangled in a tree or similar.
The gravity knife uses a button, trigger, or fulcrum lever to release the blade from both the open and the closed positions, and may use a side-folding or telescoping (out-the-front, or OTF) blade. While most military gravity knives utilize a locking blade design, other types may not mechanically lock open but rely instead upon friction to wedge the rear section of the blade against the interior of the handle.[2] Factory-made gravity knives have various types of buttons, triggers, and fulcrum levers, which usually are used to release the blade from both the open and the closed positions.
How is that an Emerson CQC7B??
I have already wrote my next letter ready to post.
Your Emerson is not a gravity knife. Would a letter from EKI to customs help you?
rolf
It's possible that your 7b had a really weak detent. My ptac, for example, can be flicked out the handle if you shake it correctly. The officer that inspected your package may have also been nitpicking for knives that day.
