Jacobitz, first of all welcome to the HI Forums.
Perchance did you sharpen your new kukri before using it? I'm betting you didn't.
The reason I ask is because quite often with a brand new kukri the original edge can be soft because of the way their hardened and then subsequently polished, this is pretty common with all charcoal forged blades no matter who makes them or where they're made....
You can check this by running a really good file along the edge and seeing if it cuts freely. If it does then keep filing until the file either starts 'skating' along the edge or quits cutting as freely as it did at the beginning. This tells you the soft over-tempered edge has been removed and you're down to the hard steel whereupon the kukri can be properly sharpened.
On the other hand if the file already 'skates' or doesn't cut freely then the original edge may either be too acute or indeed the kukri may be too hard whereas it will need to be sent back to HI for an adjustment, ie, either you getting another kukri of the same model or another of your choice if you so desire but that'll have to be worked out between you and Yangdu.
If the edge is indeed 'too acute' then you can fix it and that's what I'd try first.:thumbup:
Also way too often the kukris come with a flat ground edge instead of a proper convex and IMO this is due to the modernization of the HI arun/shop/factory/what have you.
It seems like people all over the world succumb to a bit of laziness when exposed to machinery that makes their work easier/faster.
Anyway use whichever method you're most comfortable with and increase the bevel/radius of the edge until you're satisfied with the degree of sharpness and then try the kukri again.
If you have enough experience with sharpening you'll know when you have the proper bevel/radius on the edge, if not it may take you a couple of tries to get the edge to the proper profile.
If increasing the bevel/radius substantially doesn't improve the kukri's performance then the kukri is probably too hard.
Also if you don't feel capable and don't maybe mind waiting up too ten days and are willing to pay postage both ways send it to me and I'll use my Grizz to put a proper edge on it for you.
But everybody has to start somewhere and if it was me I'd give it a try first anyway.:thumbup:
I don't think it would take me long to get around to sharpening it for you as I've been doing really well the last couple of weeks but I never know if or when the weather may change and shut me down for a few days.:grumpy:
Anyway there's the offer.
:thumbup:
