Thanks ! I would never have come to thatJewelers saw with a fine blade.
Copper is really too soft for liners on folding knives.
I was cutting copper and brass with a hand held coping saw but it was a pain. I switched to aviation snips and while they curl up, I bend them back flat as I can and for some reason they seem to always glue up flat. Maybe because I always make rectangular scales somewhat oversized versus the tang and the inner portion isn't as wavy as the portion by the cuts. Then I saw the excess by hand and then grind down to the tang. Edited to add: The snips work great on the thin G10 that I use for liners/spacers too.
But... it seems to me that gluing to a flat backer then sawing is the best way to avoid wavy copper/brass.
Well , I found that best way is as Stacy say..... About cutting .........same s**** whatever I try .I could not find my hollow Punch Tool Set to try for hole ?Very nice, you won the fight this time. What worked best and what did not so well?
Cut it slightly oversize with scissors, or saw with a jewelers saw. Mount along with the scales. File/grind to exact fit when shaping the handle. Use a fine file to remove any rough spots. Sand parallel to the spine to finish.
If I may ask a related finishing question... when fine sanding along the spines I often see some tiny but visible jagged edges (or shards) left over on the copper that's hard to remove. Any suggestions on how to avoid those instead of fighting them?
