As good a place as any to put this i guess?
The following happened 6 weeks ago to me at work
I work in a machine shop and my main duties are sharpening straight blades, wood chipper blades, zamboni blades, wood planner blades, every thing from small blades
to 10 feet long.
So anyways I just finished sharpening a paper guillitine blade that was 59" long and bolted it to its wooded board. they bolt onto board with two bolts
that screw into a threaded "t-nut" which is pressed into the board from back side . problem with that is over the years this t-nut tends to get pulled through
the wood till one day when unsuspecting sharpening person accidently drops one end of board on the floor while carrying and t-nuts pull through the board and razor sharp 59 inch
blade springs off the board and just barely slices corner off of finger. after stopping bleeding I picked up board and blade off of floorand lo-and-behold
there it lay , slice of skin with slice of fingernail still attached.
Cut so cleanly it did not hurt at all , of course while healing it hurt whenever i banged it, which was often.
If you look at 1st finger you can see two small slices that just barely took a few layers of skin off
You can also see how neatly it took piece of fingernail off as well
In this picture you can see how flat and straight the cut was. It was even flatter then it looks in picture since this was taken several
hours after cut and blood was congealed up a bit.
Did you guys know that the fingertip is only part of human body that will grow back if not too much is cut off?. Its all grown back now.
to 10 feet long.
