Assuming it's a Case blade...
Look at the pattern# stamp. If it's relatively recent-generation (last 30 years or so, at least), the CV blades will show 'CV' after the pattern#, and the stainless blades will show 'SS' after the pattern#.
And many of Case's older stainless blades might also show 'STAINLESS' on the tang stamp (seen on some of Case's 1965-'69 era blades, for example).
Very old carbon steel (CV) blades from Case will simply show the pattern# (like '2138' for the older non-stainless Sod Buster), or '6265 SAB' (Folding Hunter with 'Sabre' grind - hence the 'SAB'). Case didn't add the 'CV' stamping on their non-stainless blades until at least the late 1980s or later, IIRC.
As mentioned earlier, something acidic, like vinegar, will stain the CV blades grey/black with a pretty short exposure (a few minutes' time). Much faster, if the vinegar is very warm or hot. You can also smell the acid-iron reaction with the steel (very metallic odor - might remind one of the smell of blood as well). Stainless won't discolor at all, from such exposure.
