KC, you can use food grade mineral oil on your knives. A very light coating will do. I do this on any knife I will be using for food. Thanks to the folks here I also found out that mineral oil is good for dried out horn, stag, and bone.
CV, which is what Case uses, takes a good edge and holds it pretty well, plus resharpens easily. A lot of folks consider 1095 carbon steel to do it even better, but the higher chromium content in Chrome Vanadium (CV) makes it a "little" more resistant to corrosion than straight 1095. Carbon steel blades will discolor over time and use, and when coming into contact with food acids such as apples, etc.. A lot of carbon/CV users will go ahead and put a patina on their blades which greys and darkens them. This is essentially controlled oxidation. This is pretty much the same thing happening as with gun bluing, the oxidation forms a protective coating on the metal and a uniform coloration. Some folks also don't like the coloration and choose to just keep their knives carefully cleaned and oiled, polishing them when they do discolor. Your choice. You can do a search in the folder for patina and should find some past postings that cover various methods for putting a patina on a blade.
The Case stainless steel isn't bad, except in direct comparison with good CV/carbon steel. I would probably rank it just a tad behind well heat treated 440A or C. There have been a few Case knives/periods over the years that haven't been the best, but overall it works pretty good for general use. I've found 440A and 440C to be good stainless steels that for me acts a lot like carbon steel. By that I mean they sharpen up well, have the same "feel" on the stones to me, hold an edge and resharpen easily and quickly.
My experience with the new stainless darling that you will find on various knives like S&M, etc, which is 420HC is limited, but unimpressed. I have a couple of knives in it that I like, but I'm not that fond of the steel. When sharpening, it feels different to me. I know that isn't a quantifiable characteristic, but since I freehand sharpen it is important to me. It took a while to get to where I could get a decent edge on my 420HC blades. Even so, they still don't seem to get to that same fine edge I can get on carbon steel/CV and on 440A & C. Other's may think different and that's fine and just as valid. We each know what does and doesn't work for us.
Hope that wasn't too windy. It's a bit humid here around San Antonio, less than some places I've been, more than others. However, we get plenty of opportunity to sweat. I've not really had a problem with CV knives over the summer. I just wipe them down once in a while and if I've used them on food or other damp stuff I wipe them dry after use and give them a light coat of oil again at the end of the day. I'm fine with them taking on a patina from honest use and carry so don't, pardon the pun, sweat it.
Welcome, by the way. You will find some pretty savy fellows on here, most of which have forgotten more than I know. Pretty knice fellers too.
Amos
