Grouchy? Nahhhhh, only gets mildly peeved when politics spill into W&C or if you do something real silly like report a spammer then quote the spammer so the cleanup crew has double work...There ya go!The grouchy kitty knows all!
makes me want to dig into my 3D Mag......![]()
Pull the rubber cover off the switch button. You can pull it right off with no tools, and pop it back on just as easily. Underneath it you'll see a thing you'll have to unscrew -- the tool you need varies depending on how old yours is; you may have to improvise a tool. Once you unscrew that you can push the switch assembly out of the body. If it's badly corroded that can be pretty durn difficult, but hammering on a dowel will usually drive it out.
If you dont get your answer here try Candlepower Forums. There's a group of dedicated Mag modders there that I'm sure can answer that and a hundred other questions on Mag Lights.![]()
But be aware, its an addictive hobby, as much so as knives, I'm in its grasp right now.I'm actually considering a SF M6, and a McGizmo.
I can verify that...once you lay cash down on a McGizmo....It's ALL Over.![]()
