There are now, AFAIK, 4 different blade steels used in the EDC. 420HC, 154CM, Talonite, D2. (and 420HC and D2 in the Arclite?)
Anyways, was wondering if anyone:
1. has thoughts on which steel might be the best EDC steel. (weight vs. corrosion resistance vs. edge holding vs. re-sharpening time after serious use).
2. has pitted them in a head to head cutting comparison. (best comparison of steel's edge-holding ability so far since all knives have similar geometries).
3. knows what the hardness is for each steel used.
4. has an opinion on which is the best value for money.
Also, is there any point in putting a talonite blade on a 420HC handle?
On one hand, the blade would not corrode at the cutting edge as fast as 154CM or D2, so preserving a usable sharp edge for longer, but on the other hand, the handle is not 316 stainless or titanium (like the Mayo TNT), which means that sooner or later, your EDC becomes unusable because something (other than the talonite blade) corrodes.
Is 420HC corrosion resistant enough (for say... dive use/abuse) or was it used merely because it is cheaper to just keep using the same handles?
