Nathan, taking it out of the foil to air cool won't cause any significant decarb but will cause scale which will have to be cleaned up. Plate quench in foil is so convenient more and more makers are using it....The major carbides are uneffected by quench speed.Martensite grains may be a bit smaller but the major difference is just how exactly the martensite forms and the stresses within it.I'm not sure that there's any difference as far as corrosion resistance. [They call D2 'semi-stainless' steel but with normal care it won't rust anyway]...BTW, the Bohler website makes no mention of cryogenic cooling !Crucible mentions cryo as a option.
Mete,
See, this is why it's good having a bona fide metallurgist around. I appreciate your reply.
D2 is the one steel whose heat treat I've taken time to study. It was not discussed specifically in the one class I had that included metallurgy in college that I can hardly even remember, so my "education" is largely internet based (not really the real thing is it?)
I based a lot of this "knowledge" upon John D. Verhoeven's "Metallurgy of Steel for Bladesmiths & Others who Heat Treat and Forge Steel"
One of the things I took away from this text, and I've found a blirp this morning to quote, is the temperatures used to harden and temper stainless and the rate of cooling during the quench effects the corrosion resistance due to where chromium goes. I felt this was applicable because D2 is not so different from stainless steels in these respects. Poor assumption?
John D. Verhoeven
"there are two reasons to cool these stainless steels by quenching rather than air cooling:
(1) to reduce the amount of retained austenite as illustrated here, and
(2) to reduce K1 carbide precipitation on cooling and improve corrosion resistance."
I have read a lot of what you have to say on this forum, so I know you really know your stuff. While it is likely you know better than John D. Verhoeven, it is more likely I simply misunderstood him.
I'm saying this because it is my belief a person should know what they are talking about before offering their advice to others. Apparently I gave poor advice, but I want it known I didn't just pull it out of ass.
Any other information you'd be willing to share about heat treat of D2 would be greatly appreciated by me. It seems I don't know what I thought I did.
Thanks,
Nathan
