- Aug 27, 2004
Just got this in this morning. Now to see if I have a screw that will work for this one.
Also, it was reportedly said to need a 'once over' because the lock up is bad, and its very hard to open.
At this point I have not tested it but it appears to be fairly easy to open and on par with other Millies I have had here. Also, the lock does not defeat under spine pressure.
Chief did you spine tap it and decide the lock is bad? I have not done this but perhaps I should. I'm just curious because I'm not seeing initially any problem. I'll get back to you though. Let me look it over a bit.
STR
STR
