Bart
If you have a digital probe in your forge and can maintain 1850 deg F it can be done. It is a PITA yes as you said.
D2 will decarb fast so foil is good.
1850 deg f... soak for about 20 min..
Temper ranges from 300-500 depending on the purpose for the knife.
325 - 375 deg f works great for me on folder blades on the temper.
Double draw on the temper for 2 hours each temper cooling in still air between each, to 105 - 120 degrees.
D2 is a great steel. It cuts great and is very tough.
I like it better than some of the newer high tech carbons. Just tests better.
Web Site At
www.darrelralph.com
NEW WEB SITE TAKE A LOOK!!!!!!!!!
New projects and pics to look at !!!!
[This message has been edited by Darrel Ralph (edited 11-23-2000).]
