- Oct 7, 2017
hi how can you tell if it is real d2 steel at home thank any one for info w.smith
If your blade is relatively difficult to sharpen then it's likely D2. Like others have mentioned buying from a B/Fs Dealer is the best way of eliminating any doubts.hi how can you tell if it is real d2 steel at home thank any one for info w.smith
isnt d2 a common easy to get tool steel in china so that actually use it often in knives. that said i doubt its heat treated properly.....If its a knock off or clone its probably not d2.
You can do what I do, go to a metals treating or processing place and have it analyzed. Most of those places have laser spectral analyzers that can give you all of the mid to high atomic number constituents. They typically do not give carbon, but that would be the balance of what is left anyway along with iron.
HEre is an example of one I had done on one of my blades.
Hello, sir; What is the typical cost for this kind of analysis? Also, what steel (if known) were you testing? My math doesn’t return any results for those alloy constituents.
True. Could be real d2 but with bad heat treat. So its like its not d2.isnt d2 a common easy to get tool steel in china so that actually use it often in knives. that said i doubt its heat treated properly.....
Which is now a cardinal sin ?Am I the only one who is suspicious here?
I get the inkling that the OP bought a questionable knife from a questionable dealer and now wants to see if he got ripped off...
Which is now a cardinal sin ?![]()
