Dad's Bowie
Well this one has been in the works for quite some time. I started it well before last July.
Dad wanted a knife. This will be his second, I made him one ages ago when I was starting out, and I must say this is a hell of a lot better.
He wanted one with which he could compete at the cutting competitions if he wanted to so had to follow the usual size limits.
Original plan was for an S or part D guard, but that idea kinda changed when part of the guard started to delam when I was trying to bend it. Not hot enough.
So it was either start over or change, and he opted to just change it.
He picked out giraffe bone for the handle...which ended up being a headache =P I've not used it before, so it was a learning process.
I mortised out for the tang, glued together and went to shaping. It kept popping apart on me.
So not trusting the glues at all at this point I decided to order some corby bolts from Jantz. Not used those either before. They worked quite nicely.
Another problem arose when I got the knife glued together. I let it sit and harden up...so I thought.
Noticed a little squeeze outon handle and removed it. Next day it was back. Kept happening so I ended up removing the bolts as they hadn't set up either, put it int he vise and yanked till the handle finally came loose.
Lot of glue clean up. I'd not gotten a good mix on my epoxy, so it didn't get fully hard =[
I had an idea and the second glue up went great. I decided I needed something so I could better get an equal mix. A measuring cup! I took one of the little plastic cups from the top of a medicine bottle. Measured resin to one line, and then hardener to the double of the first line and mixed.
I think I'll buy a bunch of those cups.
All in all it turned out pretty decent. I know little spots where things could have gone better, but for one that fought me the whole way I'm happy with it, and dad seems very pleased with it.
It certainly has some heft to it as well.
Blade : 1095 with differential heat treat.
Damascus fittings (1080/15N20)
Handle : Stabilized giraffe bone with Stainless corby bolts and thong tube. - 5" Long
Blade : 10" Long - 1 15/16" Width at widest point - 5/16" Thick
Overall : 15"
8 more pictures of it on my site!
http://www.erwinknives.com/galleryhtmls/bowies/dadbowie01.html
Beau Erwin
Looks really good Beau. Has your Dad tried it out yet? Nice profile. Good job.
Brion
I think he was demo-ing it off to someone, said he got through a 2 x 4 in three whacks, but I'm thinkin it was standing it on end at an angle and going in at a diagonal to the wood, and hitting the corners. Either that or it certainly wasn't a Branson Home Depot one =P
Yeah need to go out and play with it some.
I'm gonna have to get around to making me a new one. Got a large blade in the works now but I don't think it meets comp sizes.
And thank you Beau for bringing up those Branson 2X4's, LOL. Toughest boards I have ever seen. I am glad that he is using it.
Brion
