Dagger..
I know it's not possible at all to purchase a custom Dagger from someone. Probably they wouldn't want to let it go and if they did it would be millions of dollars and then if I did buy it I wouldn't want to use it because of it being worth so much which is not why I buy knives.
Anyway, to the point, are there any Emerson dagger knock offs out there? Anything resembling it? I looked at the CRKT Stiff KISS but I want something double sided. Basically I want a dagger the size of the Emerson dagger which can be relatively easy to conceal and the knife being one piece of metal like the EKI dagger which I can wrap paracord around.
[This message has been edited by CatatonicDismay (edited 12-25-2000).]
Thanks a bunch. The JW is what I was looking for.
Holy poop. $325 plus $35 more for a blade coating. With that price it makes wish I had discovered emerson knives earlier and put in a custom order for a dagger. Well I wish that anyway but now even more so. Hmm.. I guess I'll have to do some more searching
That would be just about perfect if not for that price tag. I can only dream
Whatever happened to "Ek knives"? They made a baby Ek dagger that sounds almost exactly like what you're looking for. These were quite inexpensive ($35-$50 at knife shows)and of excellent quality. Ek made a ton of them, some with black paracord and black nylon sheathes, and some with green paracord and green nylon sheathes. I believe they also made them with leather sheathes as an option. Full tang construction, paracord wrapped, double edged spear-pointed daggers with mirror or satin finished blades. I used to own a pair of them about 6 years ago but ended up trading them off for who knows what. I'm sure there's still a bunch of them floating around out there somewhere. Blade length on these was 3 1/2" if I recall correctly.
[This message has been edited by Eric Blair (edited 12-26-2000).]
Eric, Good call. I remember them now.
Here is a picture of the Ek Boot knife.
Here is the description that went with the picture:
Ek #7 Boot Knife
The Ek #7 Boot Knife fulfills the mission - it's compact, tough and big enough. The classic combination of boot knife and
belt/boot clip leather sheath lays flat and out of the way until needed. At 7 1/4" overall with a 3" double-edged, stainless steel blade, the Ek #7 is clearly a sound choice for the back-up role.
Blade Length: 3"
Overall Length: 7 1/4"
Blade Steel: 440-C
Blade Thickness: .160" (3/32")
Rc Hardness: 57-58
Weight: 3 1/2 oz.
Finish: Satin Polished
Sheath: Leather/Boot Clip
Prices:
Black Cord: $69.95
Olive Drab Cord: $69.95
Walnut: $74.95
Micarta: $79.95
Custom Onyx, Silver & Pearl: $249.95
That was after they sold out to Blackjack knives, which has now gone belly up.
I found a couple of references to "Gary Ek", John Ek's son, who is supposed to be still making knives in the Miami area. I'll have to do some research later.
John
John, I should've known that you'd manage to produce pix of the Ek boot knife. I tried several different search engines and couldn't come up with any. I'm starting to think that you probably have all of these knives in your safe and you just toss a few out onto the floor and snap pix whenever someone inquires.
Eric
(aka Ed Jezz)
The best toys are the ones that you can put an eye out with.
Not <U>ALL</U> of them.
I usually use Google.com as a search engine. It usually gets me what I need.
John
