For daily maintenance of an EDC folder, will a leather strop do the same as ceramic rods?
I have a diamond Lansky system for re-profiling and I'm trying to decide if I should simply get a strop or get the Spyderco sharpmaker for maintenance work.
I've thought for a while now that the people that advocate a strop as the only maintenance tool must not cut much with their blades. Sure a strop will bring back an edge that's been dulled a *little*. But once you get to any kind of dullness that you'd really notice in cutting, say, a cardboard box into strips, you're WAY past what a strop can fix. At that point, you need a SharpMaker or other sharpener that can remove a decent (small) amount of steel.
I find strops to be essentially useless for maintaining blades that really see use. If you cut string and paper and other very light materials, the strop will bring the edge back. For harder use, you need a different maintenance tool.
Brian.
Brian.
Once you go into other materials for a backing, its a different ballgame. I guess one has to differentiate between backhoning and stropping and what the criteria are.
http://www.washboardsharpening.com/wear--repair.html
