Damascus-birdseye placement
Fred.Rowe
To keep the drilling to a minamum, I lay a pattern of the proposed blade atop the billet and mark the location of the ricasso and spine. Using this pattern I place the birdseyes where they will have the desired effect and drill the holes with a carbide jobber bit. I then press the billet down to the desired thickness
and get ready to grind. It's a little less work, which can be considerable when making a big blade.
Fred
Nice work.
How deep do you drill the holes?
Thanks
jimi
The billet is 3/8" thick when the holes are drilled.
If I want to end up with a 1/4" thick billet to pattern and profile, I drill the holes just slightly past the shoulders on the drill bit, that is just about 1/16".
Adding the holes on both sides: 1/16"+1/16" = 1/8" subtract this from the 3/8" billet and you end up with a 1/4" billet after you press or hammer the eyes flat.
I hope this helps, Fred
