- Nov 21, 2015
Hey everyone, so the regular steel for Chris reeve knives is s35vn i believe. But i was wondering if anyone knew what kind of steel they use for the damascus blades?
Regardless of the names and alloys, many are interested in the performance as compared to the S35Vn. I can tell you from my experiences that it is surprisingly durable but fairly different from S35Vn. For those that prefer to have a blade with that "fresh off the hones" sharpness, the DT should be the choice. For those that prefer a blade to lose its crispness quickly, but stabilizes to a "working sharp" and stays there a long time, select S35Vn.
Not sure if you wanted that info, but you got it
As a guy that enjoys sharpening about once a month (and a very sharp blade), I prefer the DT Damascus.
Did DT change up his steel recently? I thought that was the reason for the drastic change in the patterns, especially the raindrop.
When I researched prior to purchasing my DT Sebenza in Basketweave, I still came up with the AEB-L blend. I'll be curious to see if anyone else has further info on this.
We are working with Devon to tighten up the raindrop pattern but I don't know how long it will take him to get the pattern back to that tight formation. We had to change the specifications of the steel he forges and that has affected the pattern. He is experimenting to get us back but I don't know how long that process will take and when we will have that tighter pattern available.
MT Damascus said:Hello,
I talked with Devin a few years ago at the Seattle show about the loose patterns, especially the basketweave, he said CRK staring ordering wider bars, and that he was not thrilled with it. So I guess he has talked them back to regular bars where it is much easier to make a tight pattern.
Best Regards
