I was reading that. The book I'm reading claims that its pretty obvious how they made wootz steel by using molten iron instead of charcoal, how would that produce nano-tubes?
Think carbon nanotubes are new-fangled? Think again. The Crusaders felt the might of the tube when they fought against the Muslims and their distinctive, patterned Damascus blades.
Sabres from Damascus, now in Syria, date back as far as 900 AD. Strong and sharp, they are made from a type of steel called wootz.
Their blades bear a banded pattern thought to have been created as the sword was annealed and forged. But the secret of the swords' manufacture was lost in the eighteenth century.
Materials researcher Peter Paufler and his colleagues at Dresden University, Germany, have taken electron-microscope pictures of the swords and found that wootz has a microstructure of nano-metre-sized tubes, just like carbon nanotubes used in modern technologies for their lightweight strength.
The tubes were only revealed after a piece of sword was dissolved in hydrochloric acid to remove another microstructure in the swords: nanowires of the mineral cementite.
Wootz's ingredients include iron ores from India that contain transition-metal impurities. It was thought that these impurities helped cementite wires to form, but it wasn't clear how. Paufler thinks carbon nanotubes could be the missing piece of the puzzle.
At high temperatures, the impurities in the Indian ores could have catalysed the growth of nanotubes from carbon in the burning wood and leaves used to make the wootz, Paufler suggests. These tubes could then have filled with cementite to produce the wires in the patterned blades, he says.
But his suggestion isn't necessarily rock solid. Steel expert John Verhoeven, of Iowa State University in Ames, suggests Paufler is seeing something else. Cementite can itself exist as rods, he notes, so there might not be any carbon nanotubes in the rod-like structure.
Another potential problem is that TEM equipment sometimes contains nanotubes, says physicist Alex Zettl of the University of California, Berkeley. Paufler admits it is difficult to exclude the problem but says that, having studied the swords with a range of different equipment, he is convinced that the tubes he sees are from the swords.
Hope this helps.
