I am sorry for my bad English. Its not my everyday language.
Please click this link for image https://imgur.com/a/D2xFTd5
I already edited and put an image link thanksCan't see that pic kaplak
I would recommend using simpler steels. 1075 or 1084 and 15n20. The problem could be inadequate normalizing and annealing prior to quenching. Other problems could be weak welds or forging too hot. O1 and L6 have some chrome in them making them difficult to forge weld and will harden from forging temperatures causing internal stress. Most knife steels grow when quenched, O1 and L6 will grow at different rates causing stress.
Switch to 1084 and 15n20 and it will fix the problem. With more experience you can go back to the original mix.
Hoss
L6/O1 is my favorite mix for Damascus . It’s so even and uniform in hardness and great performance. The problem is L6 or some of it (with molybdenum)can cause a lot of problems in the heat treat if it’s not ran through a cycle to get it ready. I’ve used L6 for axe bits for years and I found out the hard way unless you do a full normalization cycle or a fine spheroid it will split the core sometimes during heat treat. Not the weld but the L6 itself will tear itself in two..great steel but can be tricky to work with
I hate that. Bad luck buddy sorryI normalized 2 times before quenching. I like both steel to. They can cut nail without chipping. This problem occur only some times. Maybe 1 every 7 blade that I forge. Unluckily this time was competition chopper 7.5mm thickness 15 inch total long!!. Two days forging 288 layers. A bit frustrated.
I get that with san-mai occasionally. Billets with a thicker center layer have this issue more often.
Use lower temps in HT. If you are using a forge for HT, that is also an issue. Cycle the billet before grinding to get the steel in proper condition.
As already said, switch to 1084 and 15N20 and the problem will likely disappear.
Hoss gave excellent advice. Some steels weld easier than others. Start with the easy steels like 1084 and 15N20.
I cannot buy 15n20 and 1085 in my country Malaysia. Sometimes the problem happened when I used 4340 for replace L6. Its only option in my contry 4340 and L6 or band saw blade.
Thanks do you mean too hot when I forge into knife shape or too hot when I weld them? I always use same hot from start to finish. Its welding heat.
