Well, having spent some time in the lab on this particular issue, I'm gonna be a spoilsport and disagree with everyone a little bit.
Achim is right about Tritz, he showed me the sharpest knife I have ever handled made from pattern welded steel. He and his buddy Roman are both into it in a very serious way, and they do nice work that is very much "performance first".
The 15n20 is not all that high in nickel, and it is definitely not high enough to stop carbon diffusion. Slow the rate a little bit, perhaps, but I doubt that even.
Depending on the conditions the material was welded up in (forge atmosphere and shop practice details) there might be some carbon loss in process making steel from 1095/15n20, but it is relatively insignificant most of the time, and the resulting steel *should be* at least .75C in total when done, probably a bit more. That is plenty to hit HRC 60 as quenched. Quench severity and shop practice will also play a role here as well. Mar quenching is safer, but there is a slight sacrifice in as quenched hardness (not really an issue, IMO). For all there is full hard as quenched, nothing beats water as a quenching media, but it is dangerous sometimes (things can crack). I have been using a solution of aqueous polymer for quenching some of the low hardenability steels, and find it very nice. Faster than oil, doesn't stink up the shop like oil, safer than water, and washes off with water when you're done. The one I am using is called "aqua quench 3600" fgrom Houghton. It is a chemical called polyethyloxazoline (PEO), and has slightly different characteristics from the much more common polyalkalynglycol (PAG), which is rapidly replacing oil quenching in industry due to it's much "friendlier" nature top the operators, equipment, and environment".
Much of what is being made today in pattern welded steel will get plenty hard to make a really great knife from. This was not always so.
There is a lot to this equation. Steel component selection, shop practice, then the heat treating practice. All of those things are important.
L-6 and 1095, depending on proportions and shop practice, can most definitely hit HRC 60 as quenched. L-6 and 15n20 are not the same thing, though they are somewhat similar, and give similar results in pattern welded steels for appearance, but not heat treatment. L-6 has Cr, Mo, and Ni. 15n20 has only Ni of those three. The Cr and Mo play a much larger role in the steels heat treatment behavour than does the nickel, especially in combination with nickel also. L-6 should really be called 4370, but it is not.
