Hi everyone, I tried to search for my issue but haven’t had any luck.
I have been making blades for around 6 years now and I love making Damascus, I make 95% of my blades with 1084 & 15N20. I have a physical disability so I don’t make blades as fast as others, I take my time so things like this don’t happen….. that normally works lol
My issue is when I etch this dagger it looks to have glitter or sparkles on the surface. I broke a small scrap (end cut) after heat treatment and the grains looks perfect so it’s not large grain in the center. I will add pics below with the hope that someone else has had this issue and can inform me what went wrong. I don’t want to repeat it lol
I use a heat treat oven and so all my cycles are as recommended from my steel suppliers website. Thermal cycles & quench all the same as every other blade I make. I made a blade a few days before the dagger and it was perfect. I thought maybe I just screwed up the heat treat so I went threw all the steps again to make sure it was by the book but it came out looking the same.
The only thing I did different was I ran out of 1084 and needed a few more pieces wile forging to 400 layers so I used 1075 from my same metal supplier. I don’t use other metals so nothing was mixed up on my end and the 1075 was a full fresh bar with the name & size marked on it. I also thought maybe I contaminated my ferric chloride so I drove to Radio Shack & picked up a few new bottles but with no change. I use a 3:1 ratio with distilled water. I do use canola oil heated to 140 and I change it out after about 10 blades so its still good.
Thanks in advance for any advice & happy holidays to all.
This is the blade that was made a few days before and the only difference is the dagger has 1075 added before the last forge weld.
