Damascus: Not Sure What to Expect..
Hey guys, just ordered my first damascus blade (Kershaw Shallot) an I'm not sure what to expect as far as performance, looks, or anything really... I understand that Kershaw uses a carbon Damascus so the blade can stain but aside from that; I don't know much... Anyone want to share their using experiences? Pictures welcome too :p
Thanks!!
-Jack
Thread about the Damascus steel Kershaw was using for that series.
http://www.bladeforums.com/forums/showthread.php?t=547769
Photo of a few
Here is something STR had to say about it.
Here are some pics I've been sitting on waiting to be able to post and let out there that I thought those of you asking about the Damascus Leek would find interesting. I could go on and on with some pseudo scientific mumbo jumbo if you like but I'd rather just say this from the mind of a simple backyard mechanic. If the question comes up regarding the Damascus Leek regarding the Alabama Damascus, hardness, can it be used effectively in a variety of mediums to please an end line user and so on the answer is yes. Regardless of all the desriptive phrasing and so on about rounded edges, apex, this kind of sharpening that kind, you can buy this knife and get it to where it will work well for you as a cutting tool.
I put a 15` edge on each side of this Leek using my Edge Pro right after getting it. I stropped it a few times and ran it down the 1200 grit ceramic rod and off I went. From then on to this day I have only used the little EZLapp XXF diamond sharpener you see in these pics to touch it up when it needed and with just a few light strops on that it was back up and running to another nice keen edge.
I like it and won't be getting rid of this one. Will it cut with the ZDP189 or S30V before needing a touch up? No it won't. But for what its worth I no longer have either of those ones. This one came to me as a liner lock. A pink one at that! But not being man enough to carry a pink knife I first bead blasted that off, then later swapped out the body of the liner lock with a Wal-Mart stainless frame lock. I like this much better as it sits here and it looks like Kershaw is going to be offering them just like this to you guys. I think you'll be pleased. Really I do.
Seen here is some cutting I did with it. Hemp rope which amounts to about 100 or so end cuts (slices) And not all those were done right there. I had a bigger board at first but it got chewed up and discarded so I moved to a new one. Then we have some carpet remnants cut into strips off a bigger piece, just enough to see how she did on that after the hemp cuts, then I sharpened it some and went to work on some pecan which is the darker piece and then into some pine leaving some shavings I'll use for packing materials to cushion knives shipped back to customers. Yes some of you lucky guys may see some of these very shavings in your packages. :D You don't have to thank me really>
Seriously this Damascus carbon steel Leek is a nice little folder and I like it a lot. I don't think 500 will be enough and that they'll go fast though so if you want one bite the bullet now and snag it.
STR
