Shann said:I understand at a most basic level "how" damascus is made, but how do you get a particular pattern? Thanks.
Which pattern did you want to know?Shann said:I understand at a most basic level "how" damascus is made, but how do you get a particular pattern? Thanks.
Larrin said:Which pattern did you want to know?
underaged! said:I'm not sure what you currently know but:
Damascus is made of two or more steels. It is usually layered then "forge welded", bladesmiths will then manipulate it (fold, twist, etc.) that makes the pattern. Later it's etched and that what makes the pattern visible.
The pattern can also be made by using different shapes of steel. People make it from chains, cables, I think some do it with ball bearings too.
You should search Ariel Salaverria's (sp) posts, he documents a lot of his work and shares it with us.
