Damascus Sebenza
gdw
For those of you who own the Devin Thomas Damascus Sebenza, what is your opinion of the steel? Does the edge hold up well? I am thinking seriously of getting my first CRK and I am vasillating between:
1. Large Insingo
2. Large Sebenza Damascus
It will be a user knife - so if you could provide some input on the damascus, I would appreciate it.
You're gonna get a wide variety of opinions on this one. If your first CRK is a D.T. Damascus, that pretty much would put you on the varsity team. Oh yeah, I have heard the DTD I'd great EDC steel.
Although not a Sebenza, I use a Damascus Mnandi as an EDC. IMO it has held up as well, if not better than my S30V Sebenza's and Mnandi's. The only thing worth mentioning is that the damascus blades do not open as "smoothly" as the BG42, S30V or S35V blades. At least that has been my experience after owning multiple Damascus CRK's. There is a bit of a "gritty" feel when opening them. This diminishes with use however.
I have not carried my BG42 or S35V CRK's so I cannot offer any comparison to them.
I should mention that my EDC Mnandi has a SS Damascus blade.
For the past 10 yrs I have carried a small Sebbie with a DT SS Raindrop blades (first 5-6yrs a Reg., repl by a 21). Perfect for EDC, while I can get my BG42 bladed Reg a bit more "hair-popping" sharp, the Damascus has been perfect in function, and a unique appearance a valuable addition. I have noticed that the DT steel (raindrop) seems to go longer (if only slightly) than either BG42 or SV30 before shaprening is needed, even better for rough cutting when partially dulled. If only the Insingo blade was made in damascus....
My EDC 21 also wears a Barry H CF scale.
Go for it!
Mike B.
a further note, last year as the Insingos were coming out I asked Chris Reeve at a So.CA. Blade show about damascus+Insingo, and he said to go ahead and order it, they would make it, but I have never seen one.
I've EDC'd a Damascus small regular Sebbie for a couple of years now without noticing any real change in sharpening frequency from the earlier S30V blade. Of course, about the hardest work it does is cutting the odd nylon cable tie.
Bringing back an old post, but I have the Sebe fever!!! Demascus and CF look beautiful together.. drool.. (must save for KRG.. must save). I will have one at some time though.. I VOW!!
Watch the youtube video "Using Damascus?".....it will ease your mind.
Chris generally uses Devon Thomas damascus. I went to the Thomas site and while it did not specify the hardness, the two stainless steels he uses for Chris are generally hardened to around 58 HRC, which is pretty good.
I have noticed that the DT steel (raindrop) seems to go longer (if only slightly) than either BG42 or SV30 before shaprening is needed, even better for rough cutting when partially dulled..
I agree with Mike B. on this point.
DT Stainless Damascus is stout stuff that holds an edge, bites REALLY deep when cutting, sharpens quite easily and seems to require no more anti-rust care than any other Sebenza blade steel I've owned. The sharpness is such that you can glide it though paper and make lots of nice swirls and arcs without it binding up. Potential is there if you spend the time to make it eally sharp. It makes for a great EDC piece. Know that DT stainless Damascus doesn't have that sharp "non-stainless" Damascus defined pattern look. The stainless blades look sort of flat grey and shiny, without the deep blacks in the whorls. You only vaguely notice the pattern really jump out at you when you look at the blade at various angles. One might say it's user or consumer grade in appearance -vs- the boutique custom Damascus. It's every but as sharp as custom Damascus and more resistant to rust and staining though, which makes it a great EDC choice. I like it just fine and it's sharp as hell, but don't expect it to look like a high end custom knife blade - it isn't. Resale is average price if it is used, but isn't rusted or beaten to a pulp...
I have a Large Insingo I carry quite a bit as well. I'd have a tough time choosing which one to sell if I had to. I cut more than poke, so I'd probably keep the Insingo. The blade spine is thicker for longer down the blade so I guess, in theory, it would last longer. It's more utilitarian which is a good thing for a large working knife. The S35V steel is a bit tough, but not as tough to sharpen as some would have you think. I like it actually and it sort of reminds me of tool steel. Since I use a knife to work with, and carry a gun for self-defense, I don't care that the Insingo has no sharp point. The Insingo point is probably sharp enough to do what you need to if it came to that.
Anyhow, since I cut tree roots, wood, cord, leather, skin game, pry stuff apart, etc -vs- cut paper and boxes, I'll have to vote for Insingo.
