The layers do go all the way through the steel. However steel is, well, shiny. And two steels laminated together are ... shiny.
In order to make the pattern visible, Damascus is dipped into an etching solution. The two steels respond to the etch differently (one gets darker than the other, basically), and the pattern hidden in the polished steel is now obvious in the etched steel.
Here are some instructions for etching Damascus (Thunderforge is a brand name).
Etching Instructions for Thunderforged Damascus
Step by Step
1. Clean blade with acetone. 2. Soak in solution. 3. Rinse in water & soap. 4. Oil.
Detailed Instructions
Clean your blade very well in acetone. At this point make sure you do not touch the blade with your hands, as the oils from your fingers will harm the end result. We recommend that you use tweezers. Once the blade is totally dry you are ready to dip it in to the solution.
Dip the blade point down in to the glass or plastic container that is holding the etching solution. Leave the blade in there for about 15 to 20 minutes. Pull the blade out after 15 minutes & inspect how the etch looks, if you need a higher contrast, again dip the blade back in the etching solution for additional time till you have reached the desired contrast. Do regularly check on your blade while in the solution.
Once you have reached the desired contrast you pull the blade out and immediately rinse it in luke warm water & rub hand soap on it simultaneously. At this time you will notice that a black substance will be coming off, this is the carbon that was removed during the etch. Keep washing the blade until no more black carbon is coming off.
The next step is to oil your blade using good quality gun oil.
Even after you have oiled it, you can go back to step 1 to start all over to reach a higher contrast if desired.
Etching Solution Ingredients
50% PCB Etchant Solution (available at Radio Shack®) & mix with 50% White Vinegar. Use a plastic or glass container to hold this solution DO NOT use a metal container.
