damascus steel.
nenofury
Banned, Racist Fucktard
BANNED
Could someone give me an idea of how strong this is compared to other more common steels?
Pattern welded steel comes in many many many forms, so one cannot give you an accurate sweeping comparison.
I don't consider pattern weld to be superior OR inferior to homogenous steel...though it can be pretty inferior if it's badly made and badly treated.
Pattern welding is done more for aesthetic pleasantries than performance (edit: Most good makers who use pattern weld are still out to make the best blade they can first and foremost). Good pattern-weld will perform beautifully. If you're trying to justify the higher price with performance, I think you should just spend your money on a monosteel blade.
[This message has been edited by Robert Marotz (edited 02-13-2001).]
Mr. Marotz offers sound advice.
Jerry Fisk is one of the best of the ABS smiths and a fine damascus forger. Jerry is also a straight shooter, high compliment in an arena (damascus) where hyperbole often is heard.
Jerry told me that his regular blades (simple carbon steels, from 5160 to 1084, etc) will generally outperform his damascus in cutting or chopping tests. Part of this may lie in the ease of differentially heat treating homogeneous steels. His damascus performs very well mind you, just not up to homogeneous steels. Jerry's damascus is much more desireable from a collector's standpoint, and so it holds it's edge in PRICE for resale, only.
You will, in particular, bump into hyperbole around Wayne Valochovic's damascus on occasion, some old articles, etc.
There have been so many advances in both carbon and stainless steels that there is really no way for a damascus blade to beat a well heat treated modern steel, when you compare carbons to carbons, and stainless to stainless.
One other point... stainless damascus often will not get nearly as hard as other high performing stainless steels. And so if still properly forged, softer damascus could be tougher simply because it IS softer.
The best performing stainless damascus are probably Damasteel and Mike Norris.
See this link for a reasonably detailed explaination:
http://www.bladeforums.com/ubb/Forum64/HTML/001925.html
or ... I'll just paste this post I made, can't find the link:
Devin makes some great damascus patterns.
For me personally, I'd confine Devin's *stainless* damascus to bolsters or handles or handle inlays, etc, or to the blade of an "art" knife that won't be used to cut anything (or much of anything).
Devin's carbon/carbon damascus should perform like any other carbon steel if the maker heat treats it correctly. His carbon/nickel should be lower on edge holding scale than carbon/carbon, but it will take a great looking, high contrast etch.
Devin's stainless damascus is made of AEB-L and 304SS. Fritz Schneider (beautiful steel) also uses something similar to AEBH or AEBL and a 300 series. So did Hubbard (deceased).
AEBL is about 440A or 440B in terms of metallurgy, it may have less chrome (I can't find a compositional run down on AEBH). 304SS is not martensitic, it is austenitic, i.e. it won't harden. The 300 series stainless steels do NOT make good knife blade steels what-so-ever. But the 300 resists ferric chloride etch so you get a nice pattern.
You mix AEBL and 3xx and you have something less than 440A or 440B in terms of edge holding. I believe that decarburization will pull carbon out of the AEBL and into the 300 series matrix, thereby lowering the overall carbon content of the AEBL, which lowers the ultimate hardness level. How much? Could be by a couple points on HRC and that can be substantial in terms of edge holding. Beowulf's post indicated that Devin's SS damask would harden to about Rc55, maybe Rc57 with the right batch in the right hands. This is well below the Rc59-60 that is very much commensurate with top edge holding in general (ignoring 440V at 56-58 for now).
But it sure looks good. I love the look of damascus, but I don't expect stainless damascus knives to cut particularly well... and that is my only point.
Moving up on the SS damascus cutting performance scale, Mike Norris uses AEBH, D2, and 300 series stainless...3 materials. His stainless seems to outcut most all others except maybe Damasteel, because he has D2 in the mix (1.1% vanadium and more carbon to mitigate the effects of decarburization, D2 starts at 1.4-1.6% Carbon).
Damasteel uses a powder metallurgy process to combine what is essentially a near ATS-34 clone called RWL 34 (1.05%C 14%Cr 4%Mo) and a steel called PMC 27 (0.60%C 13.5%Cr is all they say about it, close to 12C27) so it is somewhere in the AUS-6/440A/12C27 range. These should combine to make a steel that is, well, somewhere in between. I find my Damasteel blade takes a good toothy edge and holds it fairly well with a Darrel Ralph heat treat. Not bad, looks pretty good. Damasteel doesn't really give you an etch where you can "feel" the layers with your finger... it always seems to end up smooth, I think mostly because the mixture is homogeneous powder that is compressed, not layers welded together in a press or under a hammer. The layers aren't as distinct...they seem to bleed together a bit. With Norris' steel, you can actually see and feel the layers... more character, more substance.
Don't fall too hard for the "damascus cutting effect" info out there. Some knowledgeable people have written that really only a tight ladder pattern even begins to show this sort of "alternating steel, mini sawtooth" effect. You are going to do even better than this mild effect if you use diamond or other medium stones to finish your final edge to a "toothy" grabby edge, if you prefer such edges (I do).
In very general but very valid terms, anything easy to sharpen is going to be easy to unsharpen... i.e. easy to wear down the edge.
Mike Norris does do a "San Mai" styled damascus....I believe he starts with his regular ss damascus (D2, AEBH, 304) and then wraps that around a 440V core. He apparently is experimenting with a 420V core. I bought two custom hunting knives 2 years ago out of Mike's San Mai SS damascus with 440V core, and while they hold an edge very well, I would guess a pure 440V blade well heat treated would do better. I should compare them side-by-side on rope someday, and intend to.
The San Mai damascus with a "good steel" core is an excellent compromise between edge holding and beauty, and when it catches on and people learn how to heat treat it right, I hope Mike can ramp up production and make some money providing such great stuff to the public. I'm impressed with Mike's ability and innovation, since he seems to keep his eye on the "edge holding" ball. Kudos.
That Arthur Washburn post is excellent (BeoWulfTheGeat). I saved it for reference.
One note: the guys at Crucible who say "sub zero does little for knife blades" are referring to sub zero on their 420V and 440V steels I believe. That's what they told me at Guild. They did tell me, as did Darrel Ralph, that sub zero does help other stainless tool steels like ATS-34, 154CM, 440C, D2, and higher end carbons like 52100, but just has less effect on the CPM420V/440V stuff. I would surmise that the basic characteristics of 420V/440V in quench just leave less retained austenite, so the sub zero has less it can convert to martensite compared to the other steels.
what Robert has said is correct. Pattern welded steel is only as good as the welds and its mostly just for looks.
Arthur D. Washburn
Production Manager for Devin Thomas Damascus
So what constitutes a flaw in damascus (welding and such) and what does one look for visually to grade damascus (aside from personal pleasure in the pattern itself)?
Mr. Ralphs essay on working with a custom maker and in regards to damascus discusses finding an acceptable level between the customer and maker, but how does a buyer recognize these said flaws?
Phil
There is a potential benefit to forge welded steel. If the maker uses a combination of hard and soft steels, the blade will enjoy some of the advantages of both - sharpness and edge retention for the hard steel and toughness for the soft steel. In practice, though, most cutlery damascus is a combination of steel and nickel to make a more pronounced pattern. I happen to like damascus and use damascus knives often. The good ones perform very well indeed. The stainless damascus called Damasteel makes a good performing knife blade so you can have it stainless as well.
Fred
Knife Outlet
http://www.knifeoutlet.com
