- Jan 18, 2004
Got a question Sir Daniel (or anyone for that matter): I bought a supply of the larger diameter 5160 stock. I'm setting up to produce 25+ blades for my Mesquite Mistress. Each blade (finished) is roughly 1.25 tall x .25 thick x 6 long, and the tang area adds 4 inches, and is .75 tall (and still .25 thick). I plan on cutting the 5160 into lengths so that the end rough forged blade is as close to the above dimensions as possible. In fact, I need to add a little extra of the 5160 to be sure I arrive at the end result. After I have my 5160 lengths, I'll probably weld a square rod on for a handle, and get with it. I realize that the first few lengths will be trial and error, but would like to have an idea as to where to begin. Also, I'll need to figure out what to do the the drop (if any). That can go into other projects, or maybe even smaller blades, or into my big pile of damascus and clean steel pieces for canister forging later.
So, what do you think? Also, is there anything else that I should know that might be helpful concerning this particular 5160? Have we decided on forging temps, normalizing temps, HT temps and so on, or is it pretty much still experimental for the most part?
