Hi everyone,
I commissioned a chopper from Daniel a few months back in August. I liked the design of some of his smaller choppers and so when he mentioned he was working with 5/16ths S7 stock I couldn't resist. I've had it for several months now, and I've had the opportunity to play with it on several occasions now and this is my second write-up. The original can be found in the thread Daniel started about the knife after he finished it:
http://www.bladeforums.com/forums/showthread.php/890618-S7-Custom-Chopper
I basically repeated the same tests this time around, but I tried to snap photos to go along with it. Please keep in mind both my photos skills and my knife skills are very, very limited...
The actual knife is of my own design with some very helpful input from Daniel. The handle is about 5.5. inches with red G-10 and the blade is about 8.5 inches,with a primary convex chisel grind and a flat micro bevel. The tip is just a straight up flat zero chisel grind. I wanted a straight primary edge for easy field sharpening, and a chisel ground tip for scraping, notching, and planing.
As you can see, both edges came very sharp and stayed that way after the first couple uses...at this point all I had done to keep them up was steel them once and then followup with some stropping on unloaded leather.
Here's a youtube video where you can see how sharp Daniel shipped them to me...impressive to say the least, especially for the chisel ground tip:
http://www.youtube.com/user/DanielFairlyKnives#p/u/4/R-zGpnJrXGE
