- Feb 28, 2003
got my DK WSK out, and went and found me a nice sugar maple sapling that needed clearing out. figured while out and about, to make a few trap pieces...
carved up a paiute design, and also a standard heavy duty figure-4, which of course, needed testing
the knife:
http://perspicuityphotos.smugmug.com/photos/80898777-O-1.jpg
batons quite well:
http://perspicuityphotos.smugmug.com/photos/80898654-O-1.jpg
make a fast bit of kit, was able to chop these in a single go, the quarter-rounded stripped the bark in a jiffy (for real use i'd either smear the branches with ash, or just leave the bark on for concealment/natural-effect):
http://perspicuityphotos.smugmug.com/photos/80898887-O-1.jpg
http://perspicuityphotos.smugmug.com/photos/80898747-O.jpg
http://perspicuityphotos.smugmug.com/photos/80898849-O.jpg
and the artistic shot, one would not set up the vertical pole under the log, plus a bit more weight would be added, and some guide poles too...
http://perspicuityphotos.smugmug.com/photos/80898705-O-1.jpg
generally speaking, the blade did all the standard cutting, carving, shaping, notching quite well and with ease. the wsk is very lively in the hand, and comfortable to use. almost don't want to put it down.
the specs on this one are:
o 14 inches 19 ounces WSK 5160 tool steel cocobolo handle - Dan Koster
Wilderness Survival Kukri by Daniel Koster / Khukuri-Nut & Knifemaker
www.kosterknives.com
5160 tool steel, aged finish, cocobolo handles, brass pins,
14 inches 19 ounces, 1.35 ounce/inch 1/4" thick at the finger-ring
the chopping part is convexed of course, and the sweet spot is just below the eye and towards the half-rounder, depending on how/where you hold it. there's a bit more weight forward and the handle is long, allowing for some good snapping action. sharp.
this is what Dan has to say on the design portion:
"This is my spin-off of the Dave Beck WSK made popular by the movie The Hunted.
I really liked the idea of the knife, and hope to add a few of my own humble "upgrades".
Notably:
* creating more of a "chopping" profile
* short sawback, moved away from the tip (to allow for better skinning/draw-knife cutting)
* "raised" false edge - to clear sawback
* "bell" at the end of the contoured handle for comfort and control
* front and rear lanyard tubes
* finger hole in the blade for safety/control while draw-knife cutting
* finger ring instead of drop-guard for security/control
But most importantly, the blade has a distal taper and the tang has been drilled to created a well balanced knife and not just another sharpened prybar"
bladite
the knife:
batons quite well:
Notably:
bladite
