- Dec 28, 2003
I just got around to this tonight. Dan mentioned that he also wanted to see where the bend had occurred. Following the tips both Dan and Nasty gave me, I tried my first etch using this knife for practice. (Heated vinegar, etc.) It worked better than I had hoped, and gave a nice look to the blade when it was all done.
I couldn't tell if I had gone too far, or not far enough, but once I got it all cleaned up I guess I could have gone longer to get the look some of you guys have come up with.
But, you can make out the temper line, and it looks a lot clearer with the naked eye than it does with my pics. I took 3 pics and moved a little further out with each one. The center punch shows the exact spot of the original bend.
It's harder to see, but although there is some hardening along that area, the majority of the water quench seems to have hit in front of the damaged area, and at the tip, which I guess is good, because if it had bent a few inches further forward, deeper into the hardened area, I think the blade might have been ruined.
You can see the little dimple in the edge which is all that is left showing of the original damage. I need to get that rolled out now with a burnisher and the blade sharpened, and it should go away.
Thanks to everyone for their help.
Regards,
Norm
Regards,
Norm
