Darkening Damascus....
Calhoon
Hello Gentlemen! Sorry if this is a repeat question I couldn't find it in a search.
I have a damascus blade , 1084,1060,15N20 in a finished bowie. Is there a way that I can bring out the contrast in the blade? As it is it is just too faint.
Thank you in advance... Cal
I can't make out your question? I want to darken the damascus.
I'm asking what you are doing today to expose the damascus pattern. Are you doing a dip in Ferric Chloride? If so, at what concentration and for how long? Are you attempting to etch in coffee or vinegar? What are you doing today. If we know what you're doing today we can offer advice on how to tune your process.
I'm going to take a stab in the dark and assume you are doing nothing today.
If that's the case, go to an electronics supply store (such as Vetco or Radio Shack) and buy some Ferric Chloride etchant. I dilute mine to 20% (1 part FC to 4 parts water). Put it in a glass or plastic container, NOT metal. Mix up just enough for your etch. I use an emptied and cleaned olive jar for most of my etching.
Before dipping your blade, clean it THOROUGHLY. Wear vinyl or Nitrile golves, to avoid getting body oils on the piece you are cleaing. Clean it with Windex first. Rinse with clean water. Wipe it down with acetone. Rinse in clean water. Dry it off. Drop it into the etchant and leave it sitting until you have the desired darkness and depth of etch. I usually leave it in for 30 - 50 minutes. Avoid the temptation to remove it and check it frequently, as this will create an uneven etch.
When you remove it from the etchant for the last time, quickly rinse it with clean water. Wipe it down with clean cloth or paper towel. Wipe it well, a lot of black stuff will come off. Use a solution of baking soda and water to totally stop the etch. Rinse it again in clean water and wipe it down.
After that how you finish it is up to you. I usually give it a light sanding with 2000 grit sandpaper.
I won't attempt anything till I hear from the experts...
Thanks!
Thanks for your reply tryppyr I will get on it per instructions.... Cal
