Darkest fine refill for pen?
I've been playing with different refills for my tactile turns pen (short, slim) and haven't found one I like. The best medium refill I've found is EasyFlow 9000, but there doesn't seem to be a fine version. What's the darkest fine(black) refill you've tried?
I usually have a zebra gel pen on me at work, it makes a great dark black line. Not sure if a Zebra refill will work in there. They have a fine refill that I found too fine for my use, but you may like it, I'll see if i can find the actual number when I get home.
I don't have the best selection of black inks since I prefer blue, but I hope this helps a bit.
I'm not sure the tints/balance came out very well, but this is the best I could tweak. The Schmidt does write bolder, although it's hard to see that here. Mostly because I find that it globs and writes unevenly. Not a fan. The ink has a bit of a metallic sheen.
The Itoya Aquaroller is a 0.7mm ballpoint, and writes like a ballpoint. Because the ink doesn't flow/bleed as easily, it's comparable to most 0.5mm gel pens. Rather metallic sheen.
The Ohto Flash Dry is a 0.5mm gel, writes smoothly, more evenly than the Easy Flow 9000. Ink has no sheen, and perhaps looks greyish in contrast to the others (doesn't really show well in my pic), but on its own looks quite black. This is what I'd recommend to you.
I don't have any, but you might want to check out the Uni Jetstream SXR-600. They come in as fine as 0.38. Can be pricey though, but all the Jetstreams I've ever tried write exceptionally well.
(pic not mine, obviously)
Talk to Jetpens! Being a Parker refill will limit you some but, other refills can generally be trimmed to fit.
