Ankerson
Knife and Computer Geek
- Nov 2, 2002
Got the knife in the other day and have been testing it, this is my full testing process on rope, cardboard and wood.
Specs:
Blade Length - 4 3/4"
Handle length - 4 1/4"
OAL - 9"
Behind the Edge - .012"
Spine thickness - 1/8"
Blade shape - Trailing Point
Steel - CPM 10V at 63 RC
Handle Material - Desert Ironwood
Edge geometry is 15 DPS
Edge finish - 400 Grit SIC.
Started out with the rope.
Made 1180 draw cuts on 5/8" Manila rope until 20 lbs of down force was reached, there wasn't any issues with the edge other than normal edge wear and tear that I normally see cutting rope. The knife would still slice phone book paper some and printer paper easy after.
Next was the Cardboard.
Resharpened the knife before the cardboard stage, cut 5400 ft of cardboard, that's 1.02 Miles or 1.65 KM of cardboard that was cut. It would still slice phone book paper some what and printer paper easy.
Last was the wood cutting.
Wood was cut as you see in the photos making thick and thin slices, then I split another piece of wood with the knife, it held up fine with zero issues, the knife was not sharpened before the wood.
Final thoughts:
Good all around knife I believe, CPM 10V performed as expected and as shown can do some real work as shown after cutting over a mile of cardboard it would still deal with the wood without having to sharpen the knife at all before hand.
Darrin Sanders does his own heat treating as seen in the photos below.
With sister knife made at the same time.
Specs:
OAL - 9"
Final thoughts:
