Im not able to get it to a razor edge. With a file finish it feel sharper than with a stropped finish. I don't understand why since my fiskars took a shaving edge.What sort of trouble are you experiencing, specifically?
What bevel angle would you recommend? If it was a bad heat treat what could I do?My guess is that it's your bevel angle. But it could be a bad or non-existent heat treat.
If that’s the case then you’re probably rounding over the apex with the strop. Its easy to do on softer steel, which most axes are. Try reducing the angleIm not able to get it to a razor edge. With a file finish it feel sharper than with a stropped finish. I don't understand why since my fiskars took a shaving edge.
Ahh yeah that makes sense, thank you, I'll try to file it at a lower angle.If that’s the case then you’re probably rounding over the apex with the strop. Its easy to do on softer steel, which most axes are. Try reducing the angle
No I wasn't really but I was using a cheap sharpening puck. I've now reduced the angle and it's getting closer to shaving.Are you going straight from file to strop without stone?
