DC versus Satin for a User
Satin: less weight, less friction (when the width of the blade is in contact with the cuttin matterial)
DC: rust resistance. coating will eventually become scratched and worn anyways (in a user)
I believe the Satin blade is the overall users blade, altho you may find yourself laying some RenWax on after use.
Otherwise, if you're in a corrosive environment, or you're following a color theme (i.e. nothing shiny), try DC
Is the DC coating similar to the other coatings as far as durability and wearing off?
Someone else correct me if I'm wrong (it's happened before ;) ) -- but the Double Cut is not actually a coating... It means that the blade was first satin finished, then bead blasted - thus the "double" treatment.
As to durability -- in the sense of it maintaining it's "look" through hard use, I've yet to work a DC hard. But I've got 2 on the way, so i can let you know soon. But I would think the Satin would fair better to hard use just because the small scratches would be less noticeable or at least "blend" better?
Someone help us out here???? :D
I prefer satin because with a some metal polish and elbow grease you can easily bring it back to almost a mirror finish, which looks really nice imo.
