De-serrating my OHT blade
A few months ago, i was able to pick up a SAK One Hand Trekker at a real bargain price. I've been carrying it while working in around the garden and yard and have liked it a lot. As far as serrated blades go I liked the blade real well but I like a PE better.
Anyway, about ten days ago I was bored and attacked the blade first with a coarse stone, then a fine one, and then with an old razor hone. The serrations are 98% gone along with the chisel edge on the plain part.
When I am bored and take a wild hair to "improve" something I generally screw it up. I am proud to say this was not the case here and I think the OHT is now my favorite rough-use knockaround knife.
Anyone else modify theirs and like it, or not?
Yep. I altered one of mine. For general EDC I quite like the serrations but for my work they are a bit of a pain. I have to cut fine threads a lot and the serrations snag them.
If I could have found a plain edge OHT for 21.88 like I did the SE, I sure would have.
I haven't changed the serrations, but I tweaked my new Soldier a few different ways:
1) Ground off the keyring/lanyard stud - never used it, and it irritated my hand grip when in use. Like it.
2) Ground flat about half the plain-edge portion of the blade - bit me real bad when closing once, and I always have another knife on me anyway. Like it.
3) No pic ... too embarrassed. I never use the can opener, so I ground it down some in an attempt to ..... hell, I don't know what I was thinking ..... it was stupid, looks like crap, and I hate it. Should have left well enough alone. At least I left the screwdriver end of it alone!
Like you, I sometimes get bored and get a wild hair to "improve" something. Works sometimes, sometimes not! ;)
I have thought about removing the serrations on my OHT, but I'd rather just buy a plain edge one than go to the hassle.
I also removed the serrations of my "new" soldier and grinded both sides of the blade so it is not chisel grind any more, however I left a coarse edge on it so it still cuts very well on fibrous materials.
Coyote711: I wonder what did you do to the can opener? I'm thinking of modifying it into a sort of "gut hook" by adding one deep serration in the inner portion of it, has anyone tried this approach?
Regards
Jaime Orozco.
coyote711: I wonder what did you do to the can opener? I'm thinking of modifying it into a sort of "gut hook" by adding one deep serration in the inner portion of it, has anyone tried this approach?
Regards
jaime orozco.
Jaime, here's a pic of what I did - self explanatory :o. I sharpened up both sides of the "triangle" also, and the point and leading edge will work for making a draw cut in various materials - but so will a sheepsfoot or wharncliffe blade, and do it better than this modded monstrosity! Mostly it just looks weird and I wish I hadn't done it. :rolleyes:
Got bored again today, and decided I didn't like the "fleam" look, so now I just have a long screwdriver ..... may come in handy someday if I need to reach a recessed screw. ;)
Too bad ya can't get some scissors in there. That would be cool.
Well, as long as we're dreamin' ;), I'd probably replace the can opener/screwdriver with an electricians blade (or wharncliffe), and then replace the awl on back with a small regular screwdriver. :D (BTW, I love the awl on the alox SAK's, but don't find the awl on the new Soldier or OHT that useful).
This thread is goin way off topic, but I'd like an alox soldier with either a scissors or phillips instead of the awl. However, One day, I needed a hole in a flat of wood, and the soldier's awl was amazing. Drilled a perfectly round hole in a few seconds, maybe 1/4" (5mm) deep. I also put a hole in my victorinox wristwatch band between the factory holes. I use it as a crude utility blade also. Sharp enough for packing tape and cardboard. Saves a sharp main blade for tasks that require a sharp blade. The awl is a usable tool, but I could use others.
